Don't the Penski coil overs go on the other way ???to reduce unsprung weight???thats why they have the name on the end they do---yours may be upside down!!!!
Also do you have some way for your wheels to slide on the floor to equalize suspension when you lower the car ??? Two 12 inch floor tiles with grease between them under each wheel will do in a pinch if you don't have the swivel plates for alignment
Reason: added about floor tiles
