Originally Posted by elmariachi
If you aren't, the stock lines may not work.
...in which case you can easily bend your own like this from stainless or mild steel:
Buy the correct fuel log and 45 degree fitting as El suggested or from Cobra Restorers. If you make your own you can eliminate the canister filter as I did.
