Old 01-24-2012, 05:34 PM
SoTxButler's Avatar
SoTxButler SoTxButler is offline
Cobra Make, Engine: Butler...488" hi-rise, dry-sump FE s/o w/stacks
Xavier, I had the problem of stacks touching the cowl and needing to be shortened. Gene (Z-linkCobra) on this site cut mine down and he did a beautiful job. If I didn't tell you they had been cut, you would never know.
The critical thing for him to understand is the taper near the flange. With the right taper he can shorten them for you.
I will try to contact him and you can message him as well.
Good Luck
Russ
Russ
