Matt
Have had the same problem with #158 & 884, the fix was simple. You can do as Bob said, but you may want to do one other thing. I unhooked the fuel line turned on the fuel pump and drained it into a can. When the pump stoped pumping then I knew my true empty. Went to the gas stationed and bought 5 Gals, put it into the tank and set the fuel gauge to read 1/4. Remember its not how much gas you have its how much you have left. Remember to hook your fuel line back up before turning on the key.
Fred
