cobra 66,
I'm not sure a rear coil over conversion on the CR is worth while. I did it to mine but knowing what I know now I'm not sure it was the right decision. You can see some pictures in my gallery of the bottom mount in single shear. Bob is right however go with a double shear mount wherever you can. Changing springs and shocks would be a much stonger assembly than what I did with the single shear. The weight of the car sits on the spring not just an upper and lower bolt where the spring and shock mount with the coil over. I am working on getting mine modified for double shear. Good luck, John
