ok if you run a spacer they reccomend the 4 hole type where would you put the nipple? would it go in one of the rear holes or would you have to install it in the middle so it uses both holes?. i think they make a aluminum one but wouldnt that defeat the purpose for heat soak, i would think the composite would be best?.
