If all else fails after checking the conditions listed on these posts, try pulling the thermo and open it far enough to slip a asprin on each side of the valve then reinstall the stat. Fill the expansion tank and that should purge the system and solve your problem. The expansion tank should always be 1/2 full.
Good luck,
Glenn
