i like the look of the old surge tank to, i have one my problem is i have a ron davis radiator the outlet comes out the side and makes a 90 i have a degas tank that mounts to the passenger side f panel the hose runs inside the upper fender well. i have the msd blaster 3 coil. my other issue is the canton
oil filter adapter on the factory five you have to run the short
oil filter because of clearance issues with the 4 inch round frame tube. i would like to get the remote set up and move the filter to the front.
i run underdrive pulleys on my 342 since 2005 never had a issue will that little difference in pulley size really matter?.
