I assume you have an electronic speedo in which case you can just use the connection you already have but if not you can buy a speedo gear and mechanical cable from ebay (pink assuming 26" tires and 3.50 rearend).
It can accept either mechanical or electronic sensor. I have both a 3550 and a TKO 600 in my garage. Actually, you can get an app on your cell phone that will double as a speedometer if you like.
Seriously, you will be fine going to a carb.
Clois
"Let's roll"
"Be part of Something Good
