Thread
fe alternator question
10
permalink
02-06-2012, 03:11 PM
RICK LAKE
I made my own
wrench87 I made mine from aluminum stock. Used 2, 1/8" pieces. Measure the diameter you need and cut with a round saw to the right diameter. drill out the 5 holes for the rest. 4 bolt holes and 1 center hole. bevel the front edge no the spacer to not touch the inside edge of the pulley. this way you get a true spin on the pulley. Took about 20 minutes with a drill press, and belt grinder to smooth edges. You can use bolts or studs to make this spin true also with torqueing down the bolts or stud nuts. Have spin mine to 6,200 rpms and no problems. Good luck. Rick L. Ps how about a first name with all this free info????
RICK LAKE
View Public Profile
Find all posts by RICK LAKE
