02-06-2012, 09:07 PM
Cobra Make, Engine: SPF#0760
I saw one similar to this that used a brass fitting. A square block with 2 male threaded pieces 90 degrees apart. Had to remove the thermostat housing to install it - almost flush to the water pump...polished it up, put a hose on the other end, and it looked great.... A 45 degree piece might work too...
SPFWiringDiagrams@Comcast.net
