Old 02-08-2012, 06:50 PM
DanEC's Avatar
DanEC DanEC is offline
The proper way would be to grind and bevel the existing edge on the top side back about 3/4 inch. Make a stiff form and secure to the back side and lay in multiple pieces of fiberglass and resin along the length and over the beveled edge to build up the surface a little above flush. Use a fiberglass roller to roll the strips of fiberglass in tight. When it's hard flip the door over and grind the back edge back to feather it and lay strips of resin and fiberglass mat in to bring it up to a little above flush. It will probably take a combination of 6 or 7 layers of fiberglass front and rear to get the thickness. Then grind flush and trim to fit the cowl with a uniform gap. It sounds harder than it is. The hardest part is working up the nerve to grind the fiberglass back. After that it's pretty simple and just routine body work. But it means a new paint job or some careful paint matching.
