Old 02-09-2012, 08:56 AM
mjhcobra's Avatar
mjhcobra mjhcobra is offline
Cobra Make, Engine: Everett Morrison, 428
Well, it is a little late, but thanks for the knowledge. I went with the 11" set up with the forward mounted calipers to miss my coil overs in the rear. I had problems with the tires rubbing inside behind the seat that I fitted prior to ordering, so I had the wheel center adjusted an additional 1/2" in to get the clearance I needed. All is good, but what a headache. Not sure what EM was thinking long ago when they said to use the Versailles rear axle. They obviously did not figure on 15 x 10 wheels.
