I am sure you can, what it will end up costing is a big ?
Yes you will require immobiliser (Kits are available)
RhinoCo Technology :: Alarms and Immobilisers
You will need to meet emissions as per engineers requirement, which I think in WA will mean 96 engine ok with cats (ask engineer)
Ride height is 100mm minimum.
You may be required to supply torsion and beaming specs, as I would think the other DAX vehicles have most likely have been assembeld and registered in UK and imported as complete vehicles.
Maybe ask around here if other DAX owners have a copy of testing paperwork, Engineer again will advise what you need.
Cruising in 5th
