Old 02-10-2012, 05:46 PM
PaulProe's Avatar
PaulProe PaulProe is offline
Cobra Make, Engine: Hurricane - FE
Default Both directions
AJ
When fitting mine, I found I had to play both ends against the middle. I wanted to keep the seams lined up with the top bows. I lined those up then marked/indicated where the dots would go and also where the front would loop. Used a whole lot of duct (duck) tape to get it to the point I was confident enough to start gluing pieces or cutting holes.
Paul
www.65shlb.com
www.prdcrrct.com
