I knew you'd come thru Patrickt
Back in the old days of the FEs, people would take there car to local gas station(remember that the mech had to go outside and pump gas, check
oil, tire pressure AND clean the windshiels) As he went back and forth, the wires on the right side got put on correctly(1,2,3,4) and the left side sorta the same way--right in order of how they were on the vc loom bracket---5,6,7,8 which ended up with 3 cylinders being wrong wire/plug
