I did not see an overflow tank in your pics. Make sure that you have an overflow tank,(1965 era mustang tank works and looks good). The radiator cap should have the little valve that allows coolant to flow back to the block from the tank. Also 16 lbs is too much, change it for a 13 lb cap. The coolant will expand as it warms and if this overflow system is not in place you will have these problems.
