Originally Posted by wrench87
patrick, the pin is the same size .125 but it is 1 inch long the dis gear is 3/4 long, ... so far nobody i know has a new msd 8594 dis in stock so they can check it. msd said those pins are specially made for them i dont know i have to check?.
Order a new MSD 8594 distributor from Summit, compare it to yours, then return it. You might even be tempted to "borrow" the collar pin from the new distributor before you return it....
