Originally Posted by AL427SBF
Silverback's comparison falls way short of a parallel argument, determining hair color without selection criteria is not the same as what the OP asks which does have selection criteria ...
If you were going to buy, or have one built, what type of FORD engine combo would produce the highest HP/TQ per dollar, all else being equal.
RICK's response still stands and is irrefutable ...
#1 is a stroker windsor in the 393-427 range in Aluminum
Silverback did hit it square on the head.There are those of us that need the Wow factor when you open the hood and have a hard time seeing the ground because of the big block wedged between the frame rails.They do make 385 aluminum blocks also,no need for one in my car the weight bias is just the way it should.
