Mine is set up like that, its worked perfectly, I originally had the same symptoms. I have a hose from the base to the vacuum booster with a Tee close to the carb for the pcv. The vacuum advance I took off the side port on the Holley, I did have it off the base , but that is too much vacuum .
John
