Old 02-21-2012, 08:33 AM
mreid's Avatar
mreid mreid is offline
Cobra Make, Engine: Kirkham 289 FIA #690, FRPP 427 Boss engine
Important safety tip: Shut off power before removing/installing electrical components!
The problem as you are finding is that a short can cause all sorts of problems. At best the affected component stops working completely. I recommend to ring out (check continuity) of your fan circuit. It sounds lke a ground problem where you are getting stray current backfeeding through one fan. You also should double check your replacement job. There's a good chance you mis-wired it.
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
