Old 02-21-2012, 01:45 PM
patrickt patrickt is offline
Originally Posted by wrench87 View Post
ok i bought the pv 754, then i bought the pv 882 they are 2 different size valves there is no way you can put the 90 from the 882 on the 754?
Hmm, well that's strange -- I just pulled up the specs on line and the 882 is listed as having an outlet diameter of .41 while the 754 has an outlet of .50. But in my Cobra log notes they both had the same diameter back when I did my last PCV replacement. But they both will fit in your v/c, correct? I would run the 882 in there until you pick up a 90 degree fitting that has a .50 hole for the PCV. I don't know why it would change like that unless they do it so the same valve can fall under two different numbers. I'll see if I can't track down the fitting you need since it was my mistake to begin with....
