Originally Posted by ceslaw
Would those new comp cams have, per chance, a lobe separation of around 112 degrees?
Why yes indeed it does..
COMPETITION CAMS PART NUMBER: 35-518-8
ENGINE: FW XE274HR-12
GRIND #: FW XE274HR-12
INT EXH
VALVE ADJUSTMENT HYD HYD
GROSS VALVE LIFT: .555 .565
DURATION AT
.006 TAPPET LIFT 274 282
VALVE TIMING OPEN CLOSE
AT .006 INT 29 65
EXH 77 25
THESE SPECS ARE FOR CAM INSTALLED
@ 108.0 INT C/L
INT EXH
DUR @.050: 224 232
LOBE LIFT: .3480 .3540
LOBE SEPARATION: 112.0
RECOMMENDED CC VALVE SPRINGS: 987-16
