02-27-2012, 05:57 PM
KY
An 11.5/12" clutch isn't meant to be used with a SBF. It won't fit with a T5 bellhousing, or any aftermarket bellhousing.
You will need a 10.5" clutch and if you use the factory bellhousing, you'll need a diaphragm pressure plate for an easy swap.
Nobody needs an 11.5/12" clutch, not even for the biggest big blocks.
