Paint and Labels
The gold paint was sanded and roughed up a bit and then the covers were painted with Duplicolor Cast Coat Aluminum paint. After drying for several days it was baked in the oven for a couple of hours at 200 degrees. Nothing fancy. Probably similar to what Joe would have done.
The COBRA decals were added. These were ordered from Cobra Restorers. Part number DC051. You will need two.
We took our time installing the labels. First the “COBRA” and the “Shelby” were cut apart. Then a tiny notch was taken out of each corner since sharp corners tend to peel back with time. Only a small 1/8” notch is necessary. Anything larger will be noticeable.
Blue masking tape was used to define the location of the labels to assure they would be even on both sides. Use the blue tape since it will come off more easily than the yellow or green tape. There is no need to press it into place; it is only being used as a guide.
Mix a cup of water with a drop of dish washing soap. (The soap breaks the surface tension of the water). Peel the backing off the label and then dip it in the soapy water. Using a tweezers, carefully place it where it should be. The water will prevent the label from grabbing into place before it is aligned. Using a squeegee, gently force the water out.
Pull the tape off as soon as the labels are in place, and then wipe away the excess water.
