I would suggest taking pictures of your engine and then take the pictures to the BAR and ask them where they would like it hooked up.
My guess is this,
If you have breathers on both valve covers, purchase the closed system valve cover breathers. Install a T into your intake and then hook up both valve cover breathers to that. As long as your valve covers do not breathe into the open air and gets vented back into the engine, BAR should be happy.
All they care about is a closed system.
I delt with the inspectors in Modesto. They were very nice guys.
FYI, they will take pictures of your engine showing the setup. They even let me place the SB100 sticker where (in the engine compartment) that I wanted. Then they took a picture of the SB100 sticker on the car. This all gets sent to Sacramento and filed away.
They did not even check to see if it was functional. Just that it was there. I asked if they wanted me to take it off so they could see everything and all they wanted to see was if the breathers were closed system or not.
Edit:
For LodiWino, You might want to give Corky ro Mark a call at "Street Rods Plus". They might be able to help you out and possibly have everything that you need.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
Reason: See edit:
