Old 03-03-2012, 11:14 PM
menace1 menace1 is offline
Originally Posted by vector1 View Post
i use the black 'right stuff' around the coolant ports, and if you use one of the questionable gaskets like printo seal smear some around the intake ports, doesn't take much and shouldn't let the gasket move around. check all the bolts for maximum thread engagement before assembly but nothing too long.
The method above worked great for me. I set the gaskets and installed 4 threaded studs in the corners to keep the gaskets from moving and then set the manifold and torque into place.
