Old 03-04-2012, 04:48 PM
Pman1961 Pman1961 is offline
Cobra Make, Engine: Superformance SP02423 KCR 445W 611hp 599ft lbs
Pivot ball is adjusted per Ram Clutch requirements. I originally set the pivot ball in the new Quick Time bellhousing the same as the original Tremec bellhousing. When I had motor and tranny out recently I set the pivot ball a little higher which changed the angle of the clutch fork slightly but this did not affect the push rod travel length. The Kirkham reservoirs are an upgrade several Cobra owners have been doing. You can purchase the tanks and brackets from Kirkham and Olthoff sells the braided lines and hardware. So this is nothing unique and as I stated three other SPF owners local have this arrangement as well. Again....it's gotta be air!
