jhv48 and vatdevil....The master cylinder is a Kirkham unit and Olthoff supplies the lines. The attached link is of my buddies car which I have the same setup.
Winter project on my SPF I put on my original slave cylinder and bracket today replacing the slave cylinder and bracket I purchased through B2 Motorsports with same results. The master cylinder is nothing but an aluminum canister or reservoir for the fluid so it is bled when the system is bled. I was getting a very slight leak at the reservoir as the bottom would get wet with fluid. I took it off yesterday and took apart and put back together as possibly the fitting underneath needed a little more wrenching. Just went out there and looked now and it is dry. I'm not going to be able to enjoy my car until this is resolved and I'm getting a little frustrated.
