I recently had a very similar issue.
I had a 13/16" master cylinder and did not get enough travel with the slave cylinder rod to fully engage the clutch.
I replaced the master with a 1" cylinder and it solved the problem.
Since it sounds like you replaced your slave cylinder you may need to replace your master also.
