Old 03-04-2012, 09:29 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Did you use a lot of teflon tape like your buddy did????
Also---did you put the clutch disc in correctly??/(correct side against flywheel)
Did you let the weight of the trans bend the center of the clutch while aligning the trans to bell housing??(this is a common thing when amatures do a clutch)
