  #27 (permalink)
Old 03-05-2012, 06:05 AM
vatdevil vatdevil is offline
Cobra Make, Engine: Superformance #522
The master cylinder bleed port is located topside at the very end of the master cylinder. It's possible to trap air in the end of the master cylinder and not get it out by bleeding the slave cylinder. I've had this happen to me. Wilwood reccomends bleeding the master cylinder FIRST and then bleeding the slave cylinder. You can access the master cylinder bleed port by removing the driver side wheel and taking off the access panel, there are four bolts holding it on. It's tight but can be done.
