The indicator switch was a Lucas 119SA model for the AC289 Sports and 3300 series 427 Cobras. The stamped number on the switch I saw was 35644 which unfortunately is an obsolete switch. The AC factory works was supplying other Lucas switches in the mid 80's which were simular and which they had modified at the terminal ends. Not sure what the part numbers for these switches were. The indicator switch was the same for the Frua and the late Cobras. If you need the wire color codes, drop me an email. Have been trying to find one in the UK but no luck so far.
