Old 03-05-2012, 07:02 PM
kevins2's Avatar
kevins2 kevins2 is offline
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
You can start with the mounting of the fuse blocks and other small engine compartment components and then do the wiring. Can also assemble the front suspension - all part of the kit that will keep you busy for a while before ordering parts outside of the kit.
Best to read through the manual and spend some time on the ERA website deciding on the options you want. If you just put your deposit down, you'll have plenty of time to research that. Then, when the time comes to discuss what options you want, Peter can guide you as to what you can easily defer vs. what you should order with the kit.
Regards,
Kevin
