Old 03-05-2012, 08:13 PM
ERA Chas ERA Chas is offline
One big item is the rear suspension. I ordered it with my car but to tell the truth it's just been hanging under there for the last two years. Again, there is a drawback to ordering it later - it came mounted in the car and it looks like it is probably a job to install in the frame yourself.
Dan is right about everything except this-if it's a Jag. You can have ERA install the Jag into the cradle as a unit or do it yourself. If you do it, it's straight assembly of the ham and arms paying attention to shimming at the top. Then two bolts in bushings at the top and the forward pivots of the trailing arms and it's in. Slide under the car with your floor jack and jack up into place. Mine was out twice easily and here it is after complete disassembly for powder coating and reassembly. Came out again later for ventilated rotors and pin drive hubs. If I could do it alone so can you.
Never did the ERA rear assembly so can't say but a friend did and I don't remember him having any major issues getting it in place.
Chas.
