Thanks Gents
I will do some more digging and try to see if I can put some bits together, as there seems to be so many variants of these switches. it must be possible to find the correct bits to make the correct switch assy.
If any one knows any more details that would help put the correct parts together. Iwould be most grateful.
My assumption,from pictures only, is that I'm looking for a switch similar to the attached picture.
ie 9 wires controlling ....Turn signal, Main and dipped beam, flasher and horn
Arm length , approx 6" long - not sure if it should be straight or bent?
Chrome end cap
and fits inside an early MGB column cowl.
regards Steve
