Old 03-07-2012, 01:07 PM
fastd's Avatar
fastd fastd is offline
Cobra Make, Engine: ERA FIA, 351W
DougD,
I called performance friction and asked about that part # 1994; they didn't know it; can you double check and/or describe the pad that you have.
According them they rate their pads by type of compounds:
Carbon Metallic is 20 (or .20) compound
Z rated is 10 ( or .10) compound
entry level race is 97 (or .97) compound (the Tech recommended these for my application -says they are easy on the rotors and work better than Hawk HP+ on the track - he cautioned that they aren't very good on the street if they aren't heated up a little)
Do you know which one of these you use?
Regards,
Phil
