  #148 (permalink)
Old 03-08-2012, 05:11 PM
jhv48 jhv48 is offline
"Your SPF are very nice cars, nice paint and upholstery, turn signals that don't work, windshield wipers that are grounded thru the dash and are questional , loose brake bolts, coil over mounts and adjusting collars---the engines and transmissions are repeatedly mounted solely to line up the side pipes with the body instead of the driveline--oil coolers that just have lines stuck up into the fenders instead of actually hooked to the engine, underdrive pulleys to gain 5 or 6 hp, which then run the water pump and alternator too slow for cooling---I could go on and on , but many of these issues are scattered thru out the replica cobra world, but a much higher percentage are on SPF"
Hey, I resent that remark. My rear shock brackets haven't broken.........yet!
Jim
