Thread: Turbocharging
Old 02-19-2002, 12:32 PM
justa6 justa6 is offline
Default Mike
Your right about not turning the Boost Down...
I put a REALLY nice Alcohol set up on my Grand National. It allows pump gas to be used at 20lbs of boost. It is boost sensitive in that it comes on at a boost level that you select from the drivers seat. I have mine start coming in at 10 lbs boost. It also has a light that tells you its "On".
Do you have a knock detector on your setup? If you don't they make some really neat setups that will let you "see" the knock in green, yellow, red led's.
Email mail me if you want more info on the above or any other "Turbo" stuff.
Regards,
Bob
Johnex Cobra, Buick V6
