Originally Posted by Eljaro
entdoc
exactly those two damn leaking gaskets at both sides of the banjo or fuel block can be replaced by the Stat-o-Seal gaskets. These are very similar to seals used in hidraulics, basically a metalic washer with an o-ring embeded in the inside. Works wonders!
I too an looking for the correct washers, but my fuel block is the one pictured. I like the small design of the Dowty seals, but not sure of what size. I also need the correct banjo bolts for this block. Any suggestions?
