Old 03-12-2012, 05:35 PM
blykins blykins is offline
Keep priming....
You need to use a pretty hefty drill to get oil moving. The rockers are oiled through the block, not the pushrods. FE's have oil passages in the deck that feed the heads. If you'll notice, one of your rocker studs will be swedged because the oil hole sits right beside of it.
You didn't leave any galley plugs out did you?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
