Old 03-16-2012, 10:16 AM
DougD's Avatar
DougD DougD is offline
Cobra Make, Engine: Sold my beloved Shelby CSX 4068, Gessford 427 Ford
Originally Posted by Xavier View Post
Tom I have did all the trouble shooting.
Tach wiring is fine - 3 wires Ground (okay) hot (okay) tach feed (okay)
Had Autometer check out the tach (okay)
DO NOT want to take out the MSD box, a pain in the butt. Can check for 2 to 5v coming from the MSD box to the tach feed (okay) but this can actually read correctly and still be a problem because the true tool you need is an oscilloscope (don't have one).
So, no need for the lesson in trouble shooting - just wanted to know if connecting a tach to the coil while still running a MSD box will do something harmful to the tach. MSD box works otherwise.
I can try it myself to see, but did not want to burn up a good tach trying, or worse yet, something else.
I can't see that working correctly.
MSD = Multiple Spark Discharge. Multiple sparks = multiple tach signals = screwy tach readings. They wouldn't provide a tach signal wire if it was OK to hook it up to the coil.
CSX4068, '69 Bronco, '70 BOSS 302, '87 Mustang GT, '08 Roush Trak Pak
