Ill recommend if you want cast iron block is too go for a new pond or genesis cast block. They are much stronger , correctly date coded. The one thing about genuine side oiler blocks is that they are 50 years old very brittle and expensive.
Or if you wanna stick with the Shelby theme then go for a new alloy Shelby block and heads.
