  #33 (permalink)
Old 03-19-2012, 10:46 PM
Pman1961 Pman1961 is offline
Cobra Make, Engine: Superformance SP02423 KCR 445W 611hp 599ft lbs
Varmit. In my last post I indicated adjusting the clutch pedal by raising the pushrod to the upper hole. It raised the pedal an inch or more. I guess tomorrow I'm going to swap the threaded push rod with a longer unit and set to as if the clutch slave cylinder will yield a throw of about 1 1/4" then try to put in gear. If that works I may try swapping the master cylinder to a larger one that would give me more movement at the slave cylinder. Anybody can tell me how much increase in pushrod movement replacing the existing 7/8" bore master cylinder with a 1"?
