Kevin,
I went with the QuickTime as well, with a TKO 600 for the 302 in my ERA FIA and it all went together quite well.
One suggestion is to purchase the key components and their related ancillary bits and pieces, including the fasteners from the same supplier. This will most likely minimize fitment issues when the motor and drive line are installed.
There are many fine suppliers / builders here on CC that can set you up with what you need.
Once you have a list, run it past Peter, Bob or Doug at ERA to see if there are any potential issues.
