I used the Quicktime, but on a 427w in my Kirkham 289 car. I checked it, but it was perfect, so no offset pins. I had to use the toploader shallower BH and the short input shaft TKO600. Interestingly, it uses the same engine plate as the standard small block plate and I had to clearance the starter hole like Dallas described above. This BH uses a big block fork with the pivot on the driver's side. Forte's provided an external slave and bracket. I welded the clevis onto the fork and had to clearance the fork slightly so it would clear the rear flange on the TO bearing, but it works perfectly. Long story to get to the point - go with the Quicktime as it is superior, but do some research to make sure there are not any issues to address with your specific set up.
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
