  #22 (permalink)
Old 03-24-2012, 04:21 PM
blykins blykins is offline
Yes.
I've been round and round with Quicktime multiple times here in the past 6 months. Pressure plates that used to fit don't fit anymore. Clutch forks that used to work don't work anymore. Ever since Ross McCombs sold Quicktime to Prestolite, it seems like things just haven't been the same and there have been several issues pop up that didn't use to pop up.
If I remember correctly, all the SBF bells use the earlier Fox Mustang fork that you have. The big block bells use the late model clutch fork....that is, if you're going to pivot in that direction. Keep in mind that if you use this fork with a Long style or a twin disc, that it won't work....you need a notched fork so that it will clear the taller pressure plates.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
