Hi Guys,
I have been searching (with little luck) for anyone who is running or has run, 15x10 rims with 5.5 or greater BS on Jaguar Rear Hubs?
I have ordered my rims from American Racing and I need to run 0 offset for engineering requirements, however, I feel I may have stuffed up with my measurements. I neglected to take into consideration the hub fulcrum bearing boss and lower control arm (outer) mounting when measuring up for Backspace requirements etc.
Upon reflection and additional re-measuring I think the rim lip will be VERY close to rubbing on the hub!
Has anybody had any experience with this rim size/backspace combo on a Jag rear hub setup?
If so, where there any clearance issues and how did you deal with them?
Many thanks in advance.
Regards,
Roy
