Yes just because you don't need vacuum for a distributor or brakes has nothing to do with needing a PCV valve or system. The one-way PCV valve simply ensures that as manifold vacuum decreases (which is when blow-by starts to increase), the valve can open and allow the crankcase pressure to make its way back into the combustion cycle.
