Old 03-28-2012, 07:57 AM
PeteF's Avatar
PeteF PeteF is offline
Cobra Make, Engine: ERA2041 sold 2021
You say you changed cam 2 months ago. Did it have this problem before the cam change, and was that the extent of the changes? Trying to relate root cause to what parts changed. Sounds carb related to me. Are you sure all vacuum ports on the carb and manifold are hooked up? Full advance of 34 to 36 degrees is typical with vacuum plugged. Good luck.
